sbRIO -9636 5V pin header Fuse
Hey,
I got a sbRIO-9636 (Evaluation Kit) with a hat with LCD etc.
I got a problem with the 5V rail coming from the sbRIO motherboard. There is a fuse between the 5V motherboard rail and the male pin headers.(see photo). Would anyone know what value this SMD fuse is?
On the other side is 5V, and there is no short circuit on the hat (drawing 18mA @ 5V, which is reasonable)
Cheers,
Koen
(4,292 Views)
Evaluating the Manual, I see that the 5V can supply 0.9 A.  (https://www.ni.com/docs/en-US/bundle/sbrio-9605-9606-9623-9626-9633-9636-seri/resource/373378d.pdf)
So I go for a 0603 SMD fuse rated for 0.75A @ 5V
I guess this should be okay and hope this can help others.
Cheers,
Koen
(4,236 Views)
That sounds reasonable.
But as a warning to you and others reading your thread, I bet that replacing that fuse yourself would void the NI warranty on the card, so it would be a "replace at your own risk".  The recommended procedure would be to send it back to NI for repair.
(4,227 Views)
Good point, but since it is already old enough that there is no warranty on the device and NI tends to ask prices like Apple to fix stuff, it is more reasonable to get 100 fuses at Aliexpress for 8 euro and replace it myself.
(4,217 Views)
