sbRIO-9636 onboard RS232 example
Hello!
I am trying to connect a thermocouple via on-board RS-232 to sbRIO-9636.
If i create a simple .vi on RT, implementing RS-232 communication like on PC there is nothing in read buffer.
There is no problem with a thermocouple or its interface, because ive already connected it to PC using RS-232.
So, my question is - does someone have an expirience with such communication? Where i can find a simple example of sbRIO-9636 on-board RS-232 read or write?
(3,792 Views)
Did you install Serial related drivers into your sbRIO before doing all that? Do you have a screenshot on how you connect the thermocouple to the onboard RS232? What thermocouple are you using? Can you provide a screenshot of your code?
Warmest regards,
Lennard.C
Learning new things everyday...
(3,744 Views)
Thank you for answer, all is ok now. All drivers were installed. The problem was in incorrect communicating with thermocouple (protocol mistake).
(3,706 Views)
Thanks for the update. It's good to know that it has been resolved.
Cheers,
Lennard.C
(3,693 Views)
hii Doppelhertz,
can you please share the code and screenshots of your vi . It can be helpful to my application as i am having the similar problem as you had.
Thank You
(3,589 Views)
