sbRIO
Hi, I'm using an NI sbRIO for the first time and the data sheets I have aren't really helpful. I was wondering if there are more detailed data sheets or helpfiles because I'm really stuck. I am not even able to figure out how to connect the sbRIO to the PC in order to configure the FPGA (what port I should use, the data sheets I have don't even indicate the required voltage supply!!) can any one help me on this subject.
(3,723 Views)
(3,707 Views)
Thank you, that was really helpful
(3,692 Views)
the"check here" link is not working anymore. I also would need more information please.
Thanks in regard,
fani
(3,396 Views)
