sbRIO9632 setup in MAX problems
I has a single board RIO (sbrio9632) and I want to use it with labview. So, I make a network setting at the measurement & automation (MAX). After that I try to add software (next steps) but an error occurs. What actually the right way to setup the sbrio9632 in MAX? Anyone expert please advice,Im new with this. I attach the error figure. Thank you
(2,555 Views)
Hey,
There doesn't seem to be much information about that error message when searching.  This first thing I would try is to update your MAX and RIO to the latest version possible.  MAX will be automatically installed if you download a driver from ni.com/downloads.
I would try downloading latest RIO driver.  NI-RIO 12.0.  I supports back to LabVIEW 2009 SP1.
Take a look at the links I posted here too.  They may help
Regards
Lewis Gear CLA
LabVIEW UAV
(2,538 Views)
This sometime happens when your device IP is not properly configured. Make sure that your device and the Host PC are in the same gateway also are you connecting the sbRIO directly to your PC?. (Long back I had the same issue when I was in Masters. Just for fun check this 🙂 )
(2,534 Views)
Hi everyone,
I have solved the problem. I not switch off the DIP swtiches at the fpga board. After I switch off it, all the steps can be followed smoothly. Thank you everyone for your concerns Smiley Happy
(2,529 Views)
