sbRio-9637 Scan Engine
Hello there,
I´m using a sbRio-9637 to measure analog voltages. I was wondering why there is no option to put the chassis in Scan Interface programming mode? How am I supposed to use the I/O without the Labview FPGA module? Will there be an update or is a Bitstream for the FPGA avaiable?
Thank you in advance.
Gert
(3,889 Views)
Accepted by topic author GM_1
Hello Gert,
sadly the 9637 does not support the scan engine. This applies to several sbRIOs, since they are not designed for modularity (changing the application frequently and easily), but for long term use (keep a well designed application running for a while). You can only access the IOs using the LabVIEW FPGA Module.
I hope thats not to much of a problem to you.
Best Regards,
Jan Göbel
(3,824 Views)
