scale Y axis manually using Knob control ?
Hello guys,
Is there a way I can manually control the scale of Y axis using a DIAL or KNOB for waveform graphs ?
Please see attached VI.
Thanks.
Abhilash S Nair
Research Assistant @ Photonic Devices and Systems lab
[ LabView professional Development System - Version 11.0 - 32-bit ]
LabView Gear:
1. NI PXI-7951R & NI 5761
2. The Imaging Source USB 3.0 monochrome camera with trigger : DMK 23UM021
OPERATING SYSTEM - [ MS windows 7 Home Premium 64-bit SP-1 ]
CPU - [Intel Core i7-2600 CPU @ 3.40Ghz ]
MEMORY - [ 16.0 GB RAM ]
GPU - [ NVIDIA GeForce GT 530 ]
Message 1 of 8
(5,133 Views)
right click on waveform chart, create property node is your friend....
Spoiler
Message 2 of 8
(5,129 Views)
I accept that property node works. But the waveforms I am expecting doesnt have any fixed Y range. Sometimes it may be on 4300 otherwise on 10,000 range. So each time I cant keep changing the knob range. Please find the attached Vi to see what I tried.
Abhilash S Nair
LabView Gear:
Message 3 of 8
(5,124 Views)
What if the minimum and maximum range automatically adjusts itself, just like how we have autoscale enable. And then I can manually and easily control the the range of Y I want. Right now the waveform is out of range from the given values, enabling the autoscale brings it into position.
Just like a oscilloscoe,
Abhilash S Nair
LabView Gear:
Message 4 of 8
(5,120 Views)
then autoscale the graph with wiring the Y value to the knob maximum property node with an additional value for some leg room.
Message 5 of 8
(5,116 Views)
Oh we can do that! ... Let me try. Thank you
Abhi
Abhilash S Nair
LabView Gear:
Message 6 of 8
(5,114 Views)
Last question, how can I get the Y value from the autoscaled graph ? Is that also using property Node.
Abhilash S Nair
LabView Gear:
Message 7 of 8
(5,109 Views)
get it from your data array......use "array max & min" function, take the max and wire the knb property node max value, with some added leg room value.
Spoiler
Message 8 of 8
(5,106 Views)
