scale individual plots in stacked waveform chart
My question is how to set the Y-scales individually and programmatically in a stacked waveform chart. I found the Y-scales can be autoscaled by clicking on right most part of the plots. But don't know how to do it with property nodes, since there is only one property node for one chart, and I need a few property nodes for each plot in the one chart.
Thanks.
Rut
(3,288 Views)
Hi Rut,
You can use the "Active Y Scale" property to select the Y scale whose range (and other properties) you wish to adjust. Next use the "ScaleFit" property to Autoscale.
(3,273 Views)
Hi Prashant,
Thanks for your reply. I don't know how to use the Active Y scale property. Could you please show me how to use it or point me to an example? Thank you,
Rut
(3,263 Views)
I found a thread here
http://forums.ni.com/ni/board/message?board.id=170&message.id=38187&query.id=139654#M38187
It might help and I will try it first.
(3,260 Views)
Hi Rut,
The attached image sets the active Y scale to the first Y scale and then sets the autoscale ON. Change the index on the first property to access other scales you may have.
(3,256 Views)
Prashant,
Thank you very much!
Rut
(3,250 Views)
(3,194 Views)
