04-26-2007 04:17 AM
04-26-2007 06:08 AM
Hi Clement
I can't get the subVI from your VI (yours.jpg). But if I delete them, I got a change in the scaled graph. Can you post your subVI too?
Petric
04-26-2007 07:23 PM
04-27-2007 07:31 AM
Hi Clement,
I guess I found the issue. When you build a new array after the scaling, it doesn't give you da same data order as you had befor decimate 1D array. The "build array" take all datas from the first signal, then all datas from the second and so on. I think you want the 1st data from the 1st signal then the 1st data from the second and so on.. Right?
I tried to resolve it and did print screens. I have LV 8.2 and can't save in LV7
Hope that help.
05-07-2007 03:48 AM
