scan AI from all channels in 6023 daq board
I am trying to use single point scan for every Analog input channel in my 6023 board. I get a scan out of range error. I have tried multiple configurations. Basically it is only letting me scan 9 out of the 16 channels. I am scanning 0-5vdc signals. I have even tried the multiple channel scan with the same error.
(2,660 Views)
You will get a scan out of range error if your board is set for differential instead of single ended configuration. Find this property in MAX.
(2,660 Views)
Cody,
Thanks for your help. Currently all of my inputs are set for reference single ended. Does that inpact it?
(2,660 Views)
