scan for string
HI erveryone,
I am working with the Scan from String fuction, but I have a problem. The string that I have as input is "temp=32.2", so I am using the Scan function as follows:
But as output 1 I have "temp=32.2" and 0 in the output 2.
Does anyone have an idea of how to separate "temp" in output1 and 32.2 in output2?
Thanks for your help
Raymundo Cassani
Message 1 of 8
(4,446 Views)
Try a format of "%4s=%f"
Message 2 of 8
(4,442 Views)
Thank you for early answer, but, what happens if my string is size-variable? I mean for some readings I have temp=32.2 for others something like: voltage=122.1,  current=12, or humd=51.2
Raymundo Cassani
Message 3 of 8
(4,438 Views)
Accepted by topic author rCassani
The you need to program around it, for example as follows. There are many ways to do this...
Message 4 of 8
(4,436 Views)
thank you
Raymundo Cassani
Message 5 of 8
(4,429 Views)
Just make a small change to your format string, easy to do when you construct the format string from the dialog in the right-click menu.
Message 6 of 8
(4,421 Views)
he wants the leading string too, maybe....
Message 7 of 8
(4,413 Views)
That sits in the first output.
Message 8 of 8
(4,409 Views)
