scan from string error
when l test the function of scan from string. Why will have this error?
(4,251 Views)
Accepted by topic author zychocolate
use %[^.]%[.jpg] as format of string, and it will work fine.
also refer this.
--Amit
Amit
CLAD
(4,226 Views)
That Error clearly telling where you did mistake. you gave wrong format. there is no syntax with "%s.jpg".
what you want to do?
Munna
(4,221 Views)
Thank you so much!
(4,205 Views)
The lesson here is that a %s does not know where to stop.  It will just take the rest of the string.  Using the %[^.] will grab a string up to a found period (not including the period).
(4,150 Views)
