scan from string with %g - result not accurate
I am trying to use the "Scan from String" VI to convert a string into a number.  I am using "%g" as the format specifier.  The conversion is only grabbing the first six significant digits, yet I need it grab all significant digits.  Is there a real limitation here?  What could I do to solve this issue?
I have attached a simple VI to demonstrate what I'm seeing.
Joel
(3,156 Views)
It is because the display format for your numeric indicator is set for 6 significant digits.  Adjust the display format for the indicator and you will see that the other digits are there.
(3,146 Views)
Hey thanks!  I didn't realize I had to change the display format of the indicator coming off the function.  Duhhhhh.
(3,132 Views)
