Home
Community
Discussion Forums
Most Active Software Boards
Topic
Register
Login
Help
Community
Category
Board
Documents
Users
Turn on suggestions
Auto-suggest helps you quickly narrow down your search results by suggesting possible matches as you type.
Topic Options
Subscribe to RSS Feed
Mark Topic as New
Mark Topic as Read
Float this Topic for Current User
Bookmark
Subscribe
Mute
Printer Friendly Page
All Forum Topics
Previous Topic
Next Topic
scan rate using hardware timing.
vijayasiva
Member
07-09-2003
05:33 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Report to a Moderator
How can I set the scan rate accurately to 1000 Hz using hardware timing.
0
Kudos
Message
1
of 2
(2,884 Views)
Reply
Re: scan rate using hardware timing.
Photon_Dan
Active Participant
07-09-2003
12:47 PM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Wire 1000.00 to the Scan Rate input of the AI Start VI. That will set up the scan clock on the DAQ board to run at 1000 Hz. Note that it will only work on NI DAQ boards.
Daniel L. Press
PrimeTest Corp.
www.primetest.com
0
Kudos
Message
2
of 2
(2,884 Views)
Reply
All Forum Topics
Previous Topic
Next Topic
