scan slows down with each increment of loop
Hey mighty wizard
I'm not sure but I think you mixed "insert into array" up with "replace array subset" which I saw in the picture.
I think this is ok - and it should not be necessary to resize the array, if it is initialised.
Thomas
Using LV8.0
Don't be afraid to rate a good answer... 😉
Message 11 of 12
(447 Views)
Good catch!
Yes, I think you're right. I can never tell them apart from their icon, especially since the icons change depending on the array dimesionality and between palette and diagram.
Notice that "replace array subset" has two shaded squares on the right when viewed in the palette, but only one shaded square when placed on the diagram?
(Has anyone ever figured out what to connect so the "replace array subset" icon looks like its icon in the palette? 😉 ...or that it shows that little dotted arrow like in the palette view?)
Message 12 of 12
(432 Views)
