scan tolken string
Wow thanks.
My frustration all this time has been wiring the wrong output.
Need to follow my own rules
1. Don't work turn it on
2. Still don't work plug it in
Dan Shangraw, P.E.
Message 11 of 15
(2,774 Views)
Good rules!
Scan String for Tokens is a very powerful tool for parsing complicated strings.  Along with the power comes a significant level of complexity and a steep learning curve.  I have found it to be very helpful to create a number of small test VIs while learning how to use it.  The Delimiters array and the Operators array work in subtly different ways.
For your string the Match Pattern and String to Spreadsheet Array functions are probably adequate as has been suggested by others.
I have used the Scan String for Tokens for parsing assembly language as part of a cross assembler.
Lynn
Message 12 of 15
(2,765 Views)
I use the scan for tokens all over the place.
Performance is pretty good even with large strings because it doesn't split up the original string, allowing you to search in the original data and only allocate new memory for the found strings.  Reading in a big file and need to find a few small parts? Scan for tokens is your man
If your search is repetitive you can also cache the delimiters although there was a bug in this a while back (I filed it but I can't find it any more.  I think the bug was in 6.1 so it's most likely long gone by now).
Shane.
Message Edited by Intaris on 08-12-2009 08:35 AM
Message 13 of 15
(2,761 Views)
Escrito por Alain S:
Just in case you expect more than 1 string between tokens 🙂
No one asked for it, yet, but who knows what tomorrow brings Smiley Very Happy
Just that I need, Thanks!
Message 14 of 15
(2,713 Views)
Two instances per loop!?  kaboom, mind blown!  I too have struggled with this primitive for YEARS thinking it must have an obvious use case that was eluding me.  You have inspired the attached vi (back-saved to 8.0) that pulls out desired XML attributes out of a string.
Message 15 of 15
(2,019 Views)
