scarab16bit.bin error on IMAQ initialization
I just did a brand new install of LabVIEW 6.1 with the enclosed IMAQ 2.5.2. Now, every time I start Windows, I get the following error when IMAQ does its initialization:
"Can't find scarab16bit.bin data file."
It's not a big deal, since it apparently has no effect for what I'm trying to do, but it's still annoying. I checked, and 'scarab16bit.bin' isn't anywhere on my computer.
What should I do here?
(2,590 Views)
You may want to uninstall IMAQ 2.5.2 and upgrade to the latest version:
http://digital.ni.com/softlib.nsf/websearch/50F6D6F1094A033586256D52006146E0
There are also updates available instead, to IMAQ 2.5.3 and IMAQ 2.5.5, here:
http://digital.ni.com/softlib.nsf/webcategories/85256410006C055586256BBB002C0D10
The scarab16bit.bin data file should be in the C:\Program Files\National Instruments\NI-IMAQ\bin folder. After installing a later version of the IMAQ driver, this issue should go away.
Hope this helps-
Julie S.
(2,590 Views)
