scb 68 terminal block (5 V between D GND and pfi)
I'm using two daq boards, 6036e and 6731 with a SCB 68 terminal block. If I check the voltage between D GND and PFI line of the SCB 68 terminal block for both daq boards, I can see 5 V difference between them for any GND and PFI lines. so, I can not use the trigger using GND and PFI line. Is it broken or normal?
FYI, so I'm using two PFI lines, which are not biased with 5 V, for the trigger. In that case, the only falling edge works no matter what i choose the rasing or falling edge for the trigger.
(2,709 Views)
Hi scchae,
why don't you read the manual of your DAQ devices?
They mention some "pull-ip to +5Vdc" for the digital IO lines (for the 6036e): no wonder you will measure +5V between PFI and DGND…
(2,676 Views)
Dear GerdW,
Thank you for your reply. So, the hardware is normal. That is, any GND are referenced with +5 Vdc.(Q, why do they give a +5 Vdc pin more?) If I need real electric ground, I have to couple the terminal block with a real device which sends the trigger signal, not use any GND pin. Am I right?
Thank you for advance
SC
(2,663 Views)
Accepted by topic author scchae
Hi scchae,
No, GND is GND. All other pins are referenced to GND…
Do you know the meaning of "pull-up resistors"?
Because that +5Vdc pin can be used as a (small) power supply to external devices.
No.
You should connect GND with your external device GND.
There are manuals from NI describing several possible connections!
(2,661 Views)
Dear GerdW
Thank you for all your replies. Now, I understood how to measure the signal using DAQ board.
SC
(2,637 Views)
