scb68 temperature acquisition
I am trying to perform temperature acquisition with a 6062E and a SCB68. Do you know how should the thermocouple wiring be done?
How do I reffer to each channel (assuming the 2 wires of the TC need 2 different ai screws in the SCB68)? Which should be positive and wich negative?
And finally, is there a way to access the CJC reading? (this is less important to me, just for additional info)
Thank you.
(4,231 Views)
Hi Usuario
I have looked at the 6062E and the SCB68 and it appears the datasheets of each one supply a helpful amount of information that could be useful to you. (Particulary the SCB68 datasheet)
https://www.ni.com/docs/en-US/bundle/scb-68-getting-started/page/scb-68-about.html     -     SCB68 datasheet, page 6 onwards
https://www.ni.com/docs/en-US/bundle/370724c/resource/370724c.pdf    -      6062E datasheet
Hopefully this helps.
Any problems let me know.
Kind Regards
Michael
NIUK Application Engineer
(4,222 Views)
Accepted by topic author usuario
Hi usuario,
fisrt of all, you have to decide differential or singled ended mode as cabling is concerned:
https://www.ni.com/en/shop/data-acquisition/measurement-fundamentals/field-wiring-and-noise-consider...
Differential >> Positive AI (n) and Negative AI (n+8)
RSE >> Positive AI (n) and Negative AI GND
For instance, channel 0 differential mode >> Positive AI (0) pin 68 and Negative AI (8) pin 34.
If you intend to use it RSE mode, read this document:
http://digital.ni.com/public.nsf/allkb/FADEF80B5991F4AB86256FAA006E15EF?OpenDocument
As regards thermocouple signals, see this.
In order to access CJC value, you must use a property node as shown in the attached screenshot.
Hope this helps!! Saludos.
Jesus
(4,193 Views)
Thanks JesusG, thanks a lot. This is very helpful for me.
(4,186 Views)
