This widget could not be displayed.
scc 68 analog trigger with analog out
Hello, I am very new to Labview, and I am struggling to grasp this software. I have a PCI-6036E and an SCC 68. I am trying to abtain an AI from a pressure sensor, and once that value reaches a certain level, a certain time delay, and then I would like the software to remove the voltage that is constantly being sent to the control side of a relay (to open the relay). I am struggling with the "Start Analog Edge" trigger. It is continuously popping up with an error stating that I have chosen analog input, but i can choose digital...
Is this a limit due to the hardware we have in our lab?
If this isn't. How can I achieve my goal.
As I stated, this is new to me. And before referring me to examples, I have looked at a few that I feel are helpful (cont acq sample-timed loop-analog start) , but these present the same trigger error.
Thanks in advance!
Cam
(2,472 Views)
Your problem has nothing to do with LabVIEW. Have you looked at the specs for the card? You only have a digital trigger. You can acquire without a trigger and check to see of any value is greater than your threshold.
(2,469 Views)
