scc-sg24
Hi to everyone,
I'm using a SCC-68 connector with a scc-sg24 module to acquire a lod cell with this fetures:
-model FN3060
-Supply Voltage 10 Vdc
-F.S.Output 2mV/V
The problem is that the voltage value acquired in MAX is the same that I measure with multimeter as input of scc-sg24 module.
In the attached file you can see an example: the amplitude is about 1mV, but that I expect is 100mV if the gain og the module is 100.
Any suggestion about this problem ?
Thanks.
Bye
(2,822 Views)
Sorry, I think is not the correct section of the forum.
(2,818 Views)
