school project help
how do I write on the first line of the recording a name and then go as I currently code.
Message 31 of 34
(823 Views)
I couldn't decypher what you are trying to say.
Are you trying to assign a name to the waveform graph?  Ohh....  Are you trying to create a new file and assign a filename?  Well... the way you have it coded at the moment, it will prompt you for a filename and you can browse for a path...  I could not see anything else that could get a name..
Unless you are trying to assign a name for the channel which is getting plotted..  But I don't know what you are trying to do..  Can you describe again?
Message 32 of 34
(813 Views)
How to make the saved file to show the first row as my name and on the others to be the generated numbers
Message 33 of 34
(798 Views)
That is very easy.  You were so close...
See snippet below.
If you like the solutions, don't forget to give +Kudos and/or to Accept as Solution.
The string "My name is Ray"  ends with a carriage return.  If you right click on the string constant, you can select '\' Codes Display and you will see the '\n' as shown in the formatting string %.3f\n.
Message 34 of 34
(792 Views)
