scope soft front panel signal position
I'm using the new version of the Scope Soft Front Panel, 2.7f0.
How can I change the position of Ch 0 relative to Ch 1. When they are right on top of eachother, its not as clear. The older soft scope allowed them to be moved.
You can see in the attached picture that there is a little action cursor available as I hover over the channel designator on the left. But no action is available.
Anybody know how to do this? I don't want to use the offset values, because then I have to change the trigger levels as well
Paul Johnson
Renco Encoders, Inc
Goleta, CA
(2,866 Views)
Paul,
You can go the to Edit >> Device Configuration >> Click on the Channel Tab >> Change the vertical position.  This change will apply to the channel that you have selected in the drop down menu for the channel.  You could also switch to the classic mode by clicking on File >> Switch Modes.  Now, you have a vertical and horizontal slide that you can change depending on the channel that you have selected.
Hope that helps.
Raajit L
(2,835 Views)
Thanks Raajot,
Unfortunately, the first method does not work. Seems like the channels move together and can't be separated. However, changing to the classic mode with the scroll bars works fine.
Its nice having the controls for both channels available in the new mode, but I can't have the signals laying ont op of each other, so I suppose I'll just have to stick with the old mode.
Does changing the vertical postion apply to only one channel on your installtion? On mine, as soon as I pick a percentage, that same value appears if I pick a different channel on the channel selector control.
Strangely enough, the menu method works fine in the classic mode. I suspect a bug with the new mode. Otherwise, I'd be able to drag the channel indicator in the new mode,  similar to having scroll bars in the classic mode.
Paul Johnson
Renco Encoders, Inc
Goleta, CA
(2,821 Views)
