scope waveform compare
I have a tektronix waveform that I want to compare to a known good waveform, and determine if the two meet some type of pass/fail criteria. Whats a good way to do this? thanks
(2,974 Views)
This is a non trivial task. Do you know your pass fail criteria? Are you measuring a digital signal or analog? Digital would be straight forward with comparison. Analog is a lot harder. Is your measured signal going to be in the same phase as the ideal signal?
(2,974 Views)
