scpi commands for keithley 2410
Iam running the standard keithley driver program downloaded from NI. I need to disable the output enable feature. Iam using interlocks and the program resets the instrument to disable on output enable feature bypasing the interlocks. Can someone tell me what do I need to change to have the software change the always disable feature to always enable.
(2,733 Views)
Which driver did you actually download? From what page, and which link? There are several.
You would need to look at the VIs to see what they are doing. There's probably a "Default Setup" or something that is setting that parameter. It may be as simple as wiring a constant to an input of the VI, or simply removing the code. Without knowing which code you're using, that's about as far as I can go.
(2,721 Views)
