scrambled characters in response of G http-server on linux
Hello.
I am trying to set up the G Web Server from the Internet Toolkit 5.0 in LabVIEW 6.1 on Red Hat Linux 8.0. In general, that web server seems to be running.
It is configured to listen for connections on port 8080. So when I access http://localhost:8080/ with my browser it shows up a directory listing of the www-root, but all files and dirs only in one line w/o linefeed.
Navigating through the files and dirs shows only web related contents but none of my VIs. Clicking on "index.htm" brings the G Web Server welcome screen just as expected. I can navigate through the example pages, but every time I click on a VI example I only get unreadable gibberish, like a
s my browser reads the binary contents of the VI as ASCII characters. Same symptoms as discussed in Document ID: 0VJC8SSG but solution apparently not applicable.
A remote computer on Win32 or Linux behaves the same.
I already have ITK and proper VI running on Win32 and it works fine, also viewing that VI with Linux remote machine. But hosting same VI on Linux G web server only shows scrambled ASCII characters.
What am I doing wrong?
I'm out of ideas. Need help!
Regards, Ralf Richter
(2,401 Views)
rrichte1 wrote:
> Hello.
> to be running.
> linefeed.
Sounds like a little problem with the line termination. On Windows the
line termination is a carriage return/line feed. On Unix it is only line
feed.
Now HTML requires in fact as line termination and the way this
is probably solved is that a routine takes the incoming string and
replaces the \r with and \n with . Only the Unix version of the
directory listing function might use the platform specific line
termination constant so the string is really converted into
somethingsomething else..... and this is not treated as multi
line in most browsers.
> gibberish, like as my browser reads the binary contents of the VI as
This has to do with wrong Content-Type/Mime-Type in the HTTP header or a
broken browser client.
Hmm, it could be that the function to read the mime.type file to assign
the proper mime type to file endings also stumbles over the line endings
in that file. After all the Internet Toolkit for LabVIEW 5 is very old
and there might have been some fixes in the mean time. I believe I have
looked at the version which came with LabVIEW 6.1 but not sure if those
problems are solved there as I haven't really tried it out nor on
Windows nor on Linux.
Rolf Kalbermatter
Rolf Kalbermatter  My Blog
(2,401 Views)
