[scripting] control run time menu file
Hi, I wanted to ask if there is a way to link a new  *.rtm file to a particular control. I have multiple controls and I am lazy to click on each of them and link them to a new menu file manually (advanced->runtime menu->Open...)
I thought that it should be possible with scripting but I can't find the proper method or property.
Thx
LV 2011, Win7
(3,006 Views)
Hi ceties,
i was checking it shortly, checking how to script it, but i didn't find the way (with scripting). The solution could be to solve it programmatically with Shortcut Menu Activation event, where you can edit shortcut menu. See Edit Shortcut Menus at Run-Time (I guess you know this part).
If I can recomend, post this question to API Community: LabVIEW Scripting Main Board. It is dedicated boadr for scripting questions, so you might get better support there.
Martin Stefik
(2,937 Views)
Thanks for checking Stefo. I eventually overcame my laziness and clicked on each of them 🙂
LV 2011, Win7
(2,931 Views)
