scroll bar on cluster
Hello again!
Does anyone know if it's possible to put a scroll bar on a cluster?  I have a very long cluster and would prefer to put a scroll bar on it so that i can scroll through the cluster without having to scroll through the front panel.
I noticed that a string control or indicator can have a vertical scroll bar... but when i try to find this property on a cluster... it's not there!
Phil
(4,234 Views)
No.
This is nice for the idea exchange
Feel free to post..
(4,227 Views)
very dissapointing... amazing how the little things get overlooked.
Thanks!  I did post.
(4,218 Views)
there is a cluster with a scrollbar in the examples that may help you
Harold Timmis
htimmis@fit.edu
Orlando,Fl
*Kudos always welcome:)
(4,216 Views)
Thanks for the info.  I looked at the example but it won't let you scroll unless the VI is running.  Oh well...
(4,209 Views)
I'm also in need of a scroll bar on a cluster.  It's so weird that labview allows you to make a cluster smaller than its contents but without scroll bars.  That example code turns me off since it seems like a pretty large amount of code to do such a basic thing.
Anyway, another option I thought of is to use a subvi panel.  You could put all the stuff that would be in your cluster in your subvi isntead, which would have horizontal and/or vertical scroll bars.
(4,118 Views)
