scroll between plots on a graph, while VI runs
While running a VI, the graph is totally inactive. I would like to see the different plots, so I would like to scroll between plots, while the VI is running. Is there any possibility to do that?
Ussr123
(2,988 Views)
Hi Ussr,
when you want to see different plots you have to plot them in your graph (and make them visible in case they aren't).
What is "scrolling between plots"?
Why?
You really should provide an example VI!
(2,985 Views)
I dont want to display all my plots on the graph, in the same time, because they are in very different ranges and there are a plenty of them.
By scrolling I mean changing the actual display of the graph, by using the Index Display.
Unfortunately I cannot provide an example. If I would have an example, I would not have asked this question.
Ussr123
(2,980 Views)
 Maybe you could play with one listbox (user-friendly IMO) where the selected item index will determine the "plot" to be shown. Q&D (mean quick and dirty) solution attached (2013 version)
(2,956 Views)
