scroll chart
I'm using labview 8.2.  I know how to get a graph but I need a scroll chart. Where do I find the charts?
Jeff
(3,007 Views)
Place waveform chart on the Front panel.  Right click on it and select properties.
Select the Appearance Tab (should be active one) and go to the bottom right corner and select the appropriate update mode.
See image below:
R
Message Edited by JoeLabView on 07-23-2008 07:32 PM
(3,005 Views)
Thank you for replying Joe. That is exactly what I would like to do but I can not find the chart icon on the function menu. This should be trivial. Where is the icon?
Jeff
(3,000 Views)
Never mind I found. I found the controls pallette.
Jeff
(2,992 Views)
