scroll two array indicators simultaneously
How to scroll two array indicator's scrollbar simultaneously?
Thanks in advance
Message 1 of 11
(8,526 Views)
thusly
Message 2 of 11
(8,520 Views)
I used this method for both scrollbars. I connected Index Values property nodes from scrollbar1 to scrollbar2 and from scrollbar2 to scrollbar1 so that i can move any one of the scrollbars to scroll both. But when i move scrolbar 1, it moves finely. when i move scrolbar2, it shakes and moves.
is there any other way to do this?
Message 3 of 11
(8,509 Views)
Your VI works fine on my dual core but it's maxing one core.  If you have a single core you're going to bog down because you neglected to put a throttle in your while loop.  Add a Wait.vi with a 10 mSec delay and see if that helps.
EDIT:  As Jeff's example shows Smiley Wink  (anything between 10 - 200 mSec is usually fast enough for a UI.)
LabVIEW Pro Dev & Measurement Studio Pro (VS Pro) 2019
Message 4 of 11
(8,505 Views)
Accepted by topic author lxkarthi
Try this minor mod-  to allow either scroll to be active-  and as NIquist said- throttle down the loop
Message 5 of 11
(8,500 Views)
The problem that you have is that you are writing to both indexes at the same time. You need to react to which ever control that you are using. I added event structure and it seems to work better.
Tim
GHSP
Message 6 of 11
(8,497 Views)
Tim,
Yes, that will work it has a drawback. Those silly mouse move events seem to really pile up especially when the user plays around with the FP so I tend to avoid them since they either A) run full throttle and consume the core or, if a wait is added to avoid this B)lock up the front panel because of the defer panel updates being set while the many mouse move events are executed, OR if FP updates are not defered, C) cause the FP to do crazy stuff lagging behind the user's activity especially when there are other events the structure is handleing.  (Guess why I use a seperate loop for stuff like this):smileywink:
Message 7 of 11
(8,484 Views)
Yes I agree I just wanted to show an alternate method. The real problem is trying to talk to both index values at the same time.
Tim
GHSP
Message 8 of 11
(8,472 Views)
True- we can't determine the order of operation between the writes and reads in the implementation the OP presented a Classic race condition and no good way to enforce data dependancy without creating a single master scrollbar. consider the following cases:
  1. Read A  Read B Write B Write A -- or its converse simply swaps the index values and will never work right.
  2. Read A Write B Read B Write A-- A is the master- changes to B are overwritten before the can be applied and you get a "Locked" feel to B - probably what the OP observed
  3. Read B Write A Read A Write B  B is the master- changes to A are overwritten before the can be applied and you get a "Locked" feel to A
the mod I presented compares A and B if different, the value that was changed is applied to both (compare A to Last Val on SR if not = then A changed if = B must have changed)
Message 9 of 11
(8,435 Views)
Hide both Index values and use a seperate slider to move both indexes.
Visualize the Solution
CLA
LabVIEW, LabVIEW FPGA
Message 10 of 11
(8,424 Views)
