scrollbar button size
Does anyone know how to change the size of the scroll bar buttons on listbox
or string indicators? I'm trying to make my application touch screen
friendly and those little scrollbar buttoms are killing me.
Bill
(3,322 Views)
At least in LabVIEW 5.0 this is not possible, so, and supposing that you can't customize your scrollbars under LV 6, you can do the following:
Create your own scrollbar with up and down buttons, and use attribute nodes to set the scroll position depending on the button presses, this way, you can customize your own scrollbar.
Hope this helps
(3,322 Views)
Thanks. I had thought of that, but was hoping that someone figured out
where NI hid the customize capability.
Bill
Gorka Larrea wrote in message
news:5065000000050000007F320000-993342863000@exchange.ni.com...
> following:
> Hope this helps
(3,322 Views)
