scsi
Hi I'd like to send some simple commands to a device connected to an adaptec AIC 7850 SCSI card using labview. I don't have a large sum of money to spend on third party products such as those from "icon". Is there any "native solution", possibly using hacks of windows dll's ?
JC
(3,780 Views)
John, obviously NI can supply scsi interface cards but at a cost the ni 8214. This includes the windows driver. If you can obtain a driver then you can call dlls from labview.
I have no previous experience in this and I have looked at the discussions forums and also NI's resources to find nothing of any help on this particular subject. So sorry to be the bringer of bad news.
(3,780 Views)
Is it not possible to connect the SCSI card manually to Labview?
(3,522 Views)
Hi Photoniz,
There is not documentation on ours discussion forum neither are knowledgebase database. The thing with your request is that you are trying to control a third party device My suggestion and what I would try if I were you, is to communicate with the device through a different programming language, something more low level, (like C), trough the “dll”. Remember that since is a third party pci-scsi card you will have to call de manufacture of the card to help you with this task. After been able to communicate with the SCSI card in C, I would use the same scheme from LabVIEW, since you are able to call the dlls from LabVIEW using “Function Library Node”.
Some resources that might help you are: What is the best way to pass commands to a SCSI tape drive,
I hope it helps
Jaime Hoffiz
Product Expert
(3,499 Views)
