scxi 1000 with two scxi 1112 won't read simultaneously.
I have a SCXI 1000 chassis with two SCXI 1112 modules connected to them via two separate 6220 cards. I am trying to read a channel of each at the same time and it's not working. Only the first module works.
Any help will be appreciated.
Alex
(2,689 Views)
Hello aavf
How are you connecting two DAQ cards to a single chassis? Are you using two 1349?
Regards
Frank R.
(2,659 Views)
Each SCXI 1112 module has its own 6220 connected to it. The chassis can hold up to 4 different modules.
(2,653 Views)
Aavf
I know the SCXI-1000 has 4 slots, I wanted to verify your set up. Even if you are using the 4 slots you could be working in parallel or multiplexed mode.
Well, it seems to be that you are using the connection described here: Parallel mode, and your module SCXI-1112 does not support that mode: Which SCXI Modules are Capable of Running in Parallel Mode?
Regards
Frank R.
(2,649 Views)
