scxi chassis won't recognize 1163r plugin
I am using a PCI -6221 to connect to my SCXI-1000 chassis. I would like to install a SCXI 1163R plugin but the autodetect does not find it. I believe the jumpers are correct but with my limited knowledge can not be sure, they all are factory default. Card and chassis work fine with other plugins I have. Any suggestions.
(2,283 Views)
Hi Cujo
Thank you for using our discussion forums.
The SCXI 1163R’s default jumper settings configures the module to be controlled with a Digital IO device.  The PCI-6221 is an M Series MIO board, so you need to change three of the jumpers.
W2 should be set to M
W3 should be set to M
W4 should be set to A (Default)
W5 should be set to MIO
W6 should be set to S (Default)
Changing these jumper configurations will allow your 6221 to automatically detect your relay module.
Chris_K
(2,269 Views)
