search an element in a table by using a listbox
Hello Everyone,
I would like to creat a  listbox which contains a list of several strings, by choosing any string in the listbox, its tanslated value appears in the output, as each letter in the keyboard has a certain ASCII value or Binary number,
Thank you.
(2,842 Views)
Hi ysma,
You can do anything you like: Just do it!
What is a "translated value"? How do you "translate" those strings?
How is the "keyboard" connected to your listbox? How is ASCII coding related to your question?
You really need to learn to provide more/better explanations to your questions…
(2,833 Views)
Create a listbox, save data as default, extract the string, place in a indicator set to show hex-mode. done.
/Y
Qestit Systems
Certified-LabVIEW-Developer
(2,807 Views)
