search and show data from a 2d array
Hi, i want to look up for some data in a 2d array in a cluster in an array. i have done a vi and the search 1d array function im using each time return an index of element of -1 meaning the data was not found. Can someone check my vi please. In fact i want to input data and search this data in the array, the data (codes of books) is grouped in categories namely engineering, law and others. i want to search for the code corresponding to the appropriate categories and depending in which the data was found, send a signal depending in which category was the code found. Each category must have a different and distinct signal. How to do this?
(2,499 Views)
This is still the same problem as found here.  So please keep it in a single thread.
(2,493 Views)
