search array
Hello all,
I have a problem regarding to search array.
It seems like he is unable to find certain elements in the 1D array I deliver.
Because it outputs -1.
I attached my vi + the file
Koen
UnCertified LabVIEW Student
Mistakes are for learning, that's why suggestions are always welcome!
(2,633 Views)
Accepted by topic author KoenR94
You can't accurately do an equals comparison with floating point numbers.  It is just a limitation of floating points in gereral (all computer languages have this issue).  What you should do instead is check to see if a value is in a certain range to account for this limitation.
(2,630 Views)
I see, now it works.
Just multiplied everything by 100 and made it i32.
(2,627 Views)
