search for id matrix
How do you search for particular id in matrix and display all record having that particular ID
(2,360 Views)
You need to compare each element from the matrix with the searching element - and if they are the same I add the number of row and column to an another array, where you are saving the locations of found elements.
Here is example code of searching for elements:
Be aware that when you auto-index the matrix (square at the end of the wire which come from matrix) the program automatically converts matrix into an array - if you want to output matrix out of auto-indexing for-loop, you need to transfer into matrix with function called Array into Matrix.
Please let me know if this solution is the one you were looking for.
Best Regards,
Gregor Cerne
(2,336 Views)
