search for text in bundle/unbundle
I'm trying to find all instances of the text "Measurement Curve" in a bundle/unbundle node.  I did a text search in LabVIEW and it did not find any of the instances where this is being unbundled/bundled (by name), even though I can see one of them on screen while doing the search.  Either this is a really obvious bug in LabVIEW or I'm not selecting the right option.  I looked in the text search options and I couldn't find anything that seemed like it needed to be checked.  Am I supposed to go about this some other way?
(3,039 Views)
Works just fine for me. If I plop down an error cluster on the front panel and then an Unbundle By Name to unbundle the "status" element, when I search for "status" it comes up with 3 matches:
  • the label on the Boolean in the cluster on the front panel
  • the word "status" in the description for that Boolean
  • in the Unbundle By Name function
What version of LabVIEW are you using? Are you sure there are no "funny" characters in the cluster element's label?
(3,034 Views)
I'm using LabVIEW 2011.  I just now noticed that if I take the text of a case structure and paste it into the search dialog it doesn't find the case selector.  Perhaps something is screwy in my LV setup.
I have it set to search for Text, Main Application Instance, case sensitive-match whole word-regular expression all off, more options->block diagram all on.  Search Scope is set to the vi I'm searching in (not all VIs as I've got about 3000 in memory).
(3,028 Views)
That should say more options-> all on (not just "block diagram")
(3,027 Views)
I can't replicate your problem. Try it without your project loaded and see if the same thing happens with a new VI.
(3,011 Views)
It works for me as well (LV 2010).  What search scope do you have selected?
Reese, (former CLAD, future CLD)
Some people call me the Space Cowboy!
Some call me the gangster of love.
Some people call me MoReese!
...I'm right here baby, right here, right here, right here at home
(2,995 Views)
I did what you said.  It seems as if restarting LabVIEW must have fixed the problem.
In a new vi it had no problem finding the string in a case structure, when I reloaded my application, it also had no problem finding strings in case structures.
(2,966 Views)
