search in an array between two values
I have an 2d array of about 100000 sorted elements in the first index, I need to derive the subarray whose values are included between a lower and upper bounds (not the array index, but the value contained in them). The element-by-element comparison is too slow. How can I do?
(2,844 Views)
Accepted by topic author nept
If the limits exist in the array you can use "Search ordered array" (or Search 1D array) for them and then use those indeces with a Array Subset. If the limits are arbitrary you'll need to use Threshold array.
Qestit Systems
Certified-LabVIEW-Developer
(2,838 Views)
thanks!
(2,816 Views)
"Threshold 1D array " can efficiently search a nondescending array and you can round up or down to the next integer to either include or exclude the boundaries. I would recommend that instead.
(for the second limit you can even change the start index).
(2,793 Views)
Here's what I had in mind:
(2,788 Views)
