searching Routers /End Node in ListBox and save in Two ListBox
I am trying to Copy the Routers and End Nodes configured Node in Two diffent listbox..When I try to copy whole configuration from Node 3212 copy in Routers ListBox.Plz give some idea
(2,576 Views)
Hi rita,
you need to apply some kind of sorting!
IF text="router"
   THEN add entry to first listbox
IF text="endnode"
   THEN add entry to second listbox
 Instead of "listbox" you surely work with string arrays…
(2,553 Views)
Hi sir,
I made the logic but I am not able to remove the blank spaces in outout listbox.Kindly plz help.
(2,529 Views)
Accepted by topic author rita86
Hi Rita,
Use shift registers to avoid blank spaces. If you use default tunnels in case structures it will add default values in the output array.
The attached VI might help you.
Murali
CLA
*Kudos are Welcome*
(2,523 Views)
Thanks a lot.
(2,502 Views)
