second call to read tcpip is slow
@Eric1977 wrote:
I agree that the Stacked Sequence Structure should not be used but for a VERY short set of use cases, and, even then, look like they can be substituted for better alternatives based on the links you provided.
In my entire career, I have found exactly one situation where a stacked sequence is better than other alternatives.
  • exactly two frames, each with exactly the same inputs.
  • No sequence locals!
  • Only the last frame has outputs.
Message 11 of 13
(677 Views)
Code is fine.  The problem was with the hardware.
Message 12 of 13
(635 Views)
But it saves so much space! ;D
Qestit Systems
Certified-LabVIEW-Developer
Message 13 of 13
(600 Views)
