secondary dll
Here is what my .dll need:
Kernel32.dll
ntdll.dll
ole32.dll
oleaut32.dll
rpcrt4.dll
user32.dll
gd132.dll
advapi32.dll
msvcrtid.dll
msvcrt.dll
The NI system that I am using has everything up until the last one but they are from four years ago. Right now, I added all the msvc *.dll except for msvcrt.dll files and it doesn't display the secondary dll message anymore but I still get a broken arrow. When I click on it no errors are listed. So my guess might be one of the file above.
Message Edited by Newguy100 on 08-30-2005 04:43 PM
Message 11 of 14
(790 Views)
Is it ok to upgrade those files?
Message 12 of 14
(776 Views)
Some of those are windows critical files and I wouldn't recomend blanket replacement especially if the OS on the one pc is different from the others. The one file that you said is missing, I could find no information on. It looks to be a Visual C run-time engine file. Try placing just that file on the computer and see if it makes a difference.
Message 13 of 14
(771 Views)
I did try to replace it but when I restarted the NI PXI computer, I get an error so I had to go back and used the original software. I used the Dependency Software I found in Visual C and it showed that the sub VI for MSVCRT.DLL is KERNEL32.DLL and NTDLL.DLL
Message 14 of 14
(764 Views)
