secret code
sir i want a device for the automatic code lock system
even if i forgot to lock the door automatically which can be lockable or
if possible through sms the lock can be openable
Message 1 of 8
(4,554 Views)
see this link:-
http://seminarprojects.com/s/labview-door-lock
Thanks as kudos only:)
Message 2 of 8
(4,551 Views)
You have to be specific about your question. I see two more posts by you and there also you haven't provided any detailed information.
What is the hardware do you have? For SMS options you should have Modems do you have that?. Lock and unlock is a mechanical thing do you have sufficient mechanincal component like electrical actuator or its just for prototyping where you can use LED as a lock display?
Provide the details then it would be easy to give a solution.
Message 3 of 8
(4,537 Views)
I think this poster is someone who's bidding for LabVIEW jobs and wants us to write the code for him. The plethora of "projects" he's been asking about are so varied, I find it difficult to believe they're all for a specific job.
Message 4 of 8
(4,529 Views)
Yes all four  posts doesn't have any relation. 🙂
Message 5 of 8
(4,522 Views)
It's more than 4. Look back at the full post history. http://forums.ni.com/t5/forums/recentpostspage/post-type/message/user-id/230240
Message 6 of 8
(4,510 Views)
Also look at this guy pavan kalnal
Name and intensions are somewhat similarSmiley Wink
Message 7 of 8
(4,505 Views)
@danil33 wrote:
Also look at this guy @pavan kalnal
I don't think so. The requests are completely unrelated. This other poster was asking about specific examples on stacked sequence, which is a programming construct, whereas our new friend here is asking about projects.
Message 8 of 8
(4,492 Views)
