seeing frequency of curve
Hi, I made a curve fitting, and i need to see frequency at this curve, but it doesnt work.
if i enter random frequency, i get curve without any problem but if i use real frequency, curve loooks like, +2 more for every value. real frequency is so higher than values i enter.
Could anyone tell me , what can be problem here?
thanks a lot
(i couldnt add picture in other way, because this is not my pc, and i cannot install adobe, i hope it is not a problem)
(3,282 Views)
It's because of the numeric ....   the relative deviations are small ....
You can push it to better fit by:
Preprocessing your data to better fit the numeric fitting process
or tell the fit vi to work with smaller tolerances (will end at some degree... see numeric resolution, epsilon, ...)
Greetings from Germany
Henrik
LV since v3.1
(3,273 Views)
Thanks for your answer Henrik, my labview is labview 2009. i think it is possible to save vi, for previous versions, can u save it for labview 2009?
bye the way,
danke, i am also in germany:)
(3,260 Views)
Tw0 options:
wait until I get back to my PC or
play with the fitting parameters tolerance (1e-12) and fitting algorythm 😉
Henrik
LV since v3.1
(3,245 Views)
i made algorythm "givens" and tolerance as u said 1e-12. it made a nice curve:)
thanks
(3,237 Views)
