segmentation fault in Labview 7.1.1 for Linux (RH9)
I work on a quite big application that runs on a Red Hat 9.0 Linux machine.
I get a SIGSEGV that kills my application from time to time :
LabVIEW caught fatal signal
7.1.1 - Received SIGSEGV
Reason: address not mapped to object
Attempt to reference address: 0x22
Segmentation fault
I'd like to know how am I supposed to troubleshoot that error, I don't have a clue...
I saw a few posts about issues with Fedora Core distributions, but they don't apply to me.
Any idea?
Thanks a lot,
Alex
(3,158 Views)
Isn't there a way to edit posts?
Some additional information:
The problem seems to disapear when I remove my serial ports aliases in visaconf.ini, which means two things :
1) The serial ports (there's four of them) are not initialized anymore
2) The application continously communicate with a serial instruments on COM1 - that communication is obviously broken... We manage these errors so nothing wrong happens
BTW, the problem occurs only at run-time, wheter I run the application as a VI or as a built executable
Alex
(3,147 Views)
Did the .ini edit solve the problem?
I just upgraded from 8.2 to 8.5 and now have SIGSEGV fatal errors.
(2,977 Views)
Hi Alex,
Are you using a 32-bit or 64-bit machine?  This segmentation fault error will occur if trying to install LabVIEW for Linux on a 64-bit machine.  If you are using a 32-bit machine, the following article lists steps on how to resolve this error so that you will immediately be able to use LabVIEW.  Hope this helps!
Why Do I Get Segmentation Fault Errors When Installing LabVIEW 7.1 and Earlier on Linux?
(2,955 Views)
