select button
I have a set of buttons that I want to set so only one button can be pressed or selected. I am not sure how to do this. Any ideas?
(3,606 Views)
This is an active control, and therefore requires some code.
Do a search for "radio buttons". There are several examples out there. My personal preference is to use clusters to group the buttons together, as it allows you to put individual characteristics (names for example) on the buttons.
(3,606 Views)
The easiest way of doing this is to use a slider control that has been modified graphically to resemble a series of radio buttons. Do a search of this site as I have posted an example of this approach in the past and it works really well. Contact me directly if you can't find them and I'll email them to you directly...
Mike...
mlportersr@webtv.net
Certified LabVIEW Architect
LabVIEW Champion
(3,606 Views)
