select multiple files and folders
Is there any file dialog vi that allows you to select multiple files and folders? I am looking at file dialog in advanced file functions but it only allows file selection if I want to select multile items - it doesn't allow me to select folders.
Message 1 of 16
(10,813 Views)
When you drop the file dialog.vi in the BD a configuration menu opensand you can uncheck Limit selection to single item and you can select File or folder.
Ben64
EDIT: You're right, when we uncheck Limit selection it greys out the selection menu. Maybe you can use the Recursive File List.vi.
Message 2 of 16
(10,804 Views)
But I wan to select *multiple* files and folders.
Message 3 of 16
(10,801 Views)
Uncheck the "Limit Selection" box in the Express VI and the function will allow you to select multiple files and folders.  Hold CTRL while selecting the files.  It will return an array of paths.
aputman
Message 4 of 16
(10,789 Views)
Correction:  It only returns files.  My bad.
aputman
Message 5 of 16
(10,784 Views)
Uncheck the "Limit Selection to One Item" and select the "Files and Folders".
Message 6 of 16
(10,760 Views)
File Dialog doesn't let me select "files of folders" if I uncheck "Limit Selection to One Item". The function automatically select "files" if I uncheck "Limit Selection to One Item"
Message 7 of 16
(10,749 Views)
That doesn't work to select multiple folders.  You can only select files with this option unchecked.
aputman
Message 8 of 16
(10,748 Views)
Roll your own using a listbox.  I made this reentrant VI that calls itself if only one folder is selected, otherwise it returns the selected folders.  The attached VI needs a bunch of refinement (error handling, at least), but it does what I think you want.
Jim
Message 9 of 16
(10,735 Views)
I tried hacking into the core built-in function (File Dialog);  I was able to set the selection mode flags to disallowed values:
When I ran it, it would actually let me select multiple files or folders, but unfortuneatly the output only returned the files I selected, not any of the folders.
Message 10 of 16
(10,697 Views)
