select one of multiple waveforms
Hope someone can help me out here. I am acquiring 6 channels of data using a 6052 card. The data is then being displayed on a Waveform Graph. I would like the users to have the ability to select which channel of data they would like to view. As it stands now, all 6 channels are being displayed at the same time which is confusing. I have tried to no avail and could really use some expert help on this. The channels are all named but are selected arbitrarily. In other words, the channel assignments to the AI Waveform vi are selected by an I/O control that the user uses to select which channels to acquire data on. It might be 1 channel or any combo of channels. Ay ideas/help will be greatly appreciated.
(2,518 Views)
You can use a property node for the waveform graph to do this. One of the properties for a waveform graph is if the plot is visible. You can select the active plot and then set that plot visible or not by toggling a boolean. I will attach an example in 6.0 that demonstrates this.
(2,518 Views)
