select values from an array
I am a beginner labview user,
I am making a case structure that currently has a random number (0-1) numeric wired to the selector terminal.  The case structure is executing true/false events based on that. This is working fine.  My problem is that I want the 0s and 1s to be predetermined. For example, I would want these numbers to be inputted one by one: 1 1 1 1 1 1 0 0 1 1 1 1 1 1. I do not want to manually click/input the numbers using numeric controls.
I used an array to do this but it is giving me an error when i am trying to wire the array to the selector terminal.
Please let me know if you need further clarification.
(3,838 Views)
Try enclosing the case structure inside a for loop. Wire the array through the border of the loop.  The tunnel will automtically set to auto-indexing.
Also it is generally not a good idea to wire floating point numbers to the selector terminal. Which case would you expect when the value is 3.5? Switch to an integer data type.
Lynn
(3,835 Views)
I dont quite understand.  This is a simplified version of what i am trying to do.  But instead of random 0 and 1, I would like chosen 0s and 1s. For example, the sequence 1 1 1 1 1 1 0 0 1 1 1 1 1 1
(3,830 Views)
Is there a better method to do this other than an array?  Remember, i do not want to input these numbers.  They need to be hardcoded.
(3,827 Views)
Array is a good way. If the arrays are large or could change rarely, storing the data in a file which could be read in and then processed might be an alternative.
You could also store the data as booleans directly.
Here is an example to give you a few ideas.
Lynn
(3,822 Views)
Thank you!! That helped alot.
(3,791 Views)
